Help FAST: B cam and speed density. can it be done???
  • Thread starter Thread starter UnderPressureGT
  • Start date Start date Dec 20, 2003
UnderPressureGT
2,285
TR- Jersey Shore
Dec 20, 2003
  • Dec 20, 2003
I have a stock 87GT with 96K on it.. My father is going to buy the B303 cam, lifters, pushrods, valvesprings and gaskets.... Will i have the SLIGHTEST chance of it running right if i just do the swap (take old cam out.. put new one in).... Heads and intake are stock for now...if i can get it to run right, ill leave it... But later down the road when i rebuild the motor and put a set of heads on it, i will swap to mass air... but for now.. is this dooable??? I heard its a 50/50 hit or miss with this cam.. Ide like to hear from people that done it with success or failure.
thanks
giddyup306
3,041
Dec 20, 2003
  • Dec 20, 2003
Get an electric vacuum pump.
bmo37
2,368
New Jersey
Dec 20, 2003
  • Dec 20, 2003
I agree the LSA on that cam is 112 and doesn't produce enough manifold vaccum so you have idle/driveability issues not to mention power braking issues.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Dec 20, 2003
  • Dec 20, 2003
You may as well do the maf swap and avoid all the crap Joe.......
mike keirstead
1,121
ROLLING A JOINT
Dec 20, 2003
  • Dec 20, 2003
There are better cams out there for speed density that will give you less hassle. Its going to take some tinkering to get the thing to idle.....
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 20, 2003
  • Dec 20, 2003
To paraphrase Mike K. - there are better cams out there...that will give you less hassle.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Dec 21, 2003
  • Dec 21, 2003
The B cam can be had for less than some aftermarket cams, but don't buy one that could lead to problems - you'll regret it. Here is a graphic of some cams that are SD compatible. Comp Cmas are in orange and Crowers are in blue.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Dec 21, 2003
  • Dec 21, 2003
image didn't attach..............
Jkstang78
1,510
long island N.Y.
Dec 21, 2003
  • Dec 21, 2003
I had a b303 in my speed density car for 3 years with now dirve ability problems. You will have to play with it. If I rember right I had the timing at 14* and, the rpms at about 900 -1000. A little high yes I know but no one know that there was a cam it that car. So yes I say it would work.
UnderPressureGT
2,285
TR- Jersey Shore
Dec 21, 2003
#10
  • Dec 21, 2003
  • #10
Thanks.. I know a decent deal of which cams work with SD anbd which dont and why they dont.. I was just wondering this because i WILL have a decent heads cam intake combo which will be followed.....
AFR 165's, performer RPM intake and B cam... by that time, i WILL be mass air... i was just wondering if i do the cam, i can get it to work for the time being..
This is a dumb way of thinking, but the way i see it.. Im spending all this money on my motor, i at least when that cam to lope BIGTIME!! Im not all about the sleeper look.. If i buy a cam, i want that ***** to lope! If i buy a blower, that better WHINE!!! My cousin has a B cam in his notch and the power after 3500 is sweet!! pulls damn hard up to 6800 and not to mention has the idle that i love!
T
truly insane 87
160
at the bar
Dec 22, 2003
#11
  • Dec 22, 2003
  • #11
i did this years ago too. it works but you will run just a little richer. also play with your timing and i would have at least 3.73gears.
the best thing to do is after you install it run the car @ WOT as many times it takes for the computer to learn it will learn faster this way usually 4-5 times up and down the street.
also if it still isnt idling i have another trick let me know what happends.
cardudeusa
1,744
Home of the Florida Gators!
Dec 22, 2003
#12
  • Dec 22, 2003
  • #12
One of my friends had the B cam on his SD car for about a year, only time he had problems was with the a/c on pressing the brakes the car would stall sometimes. We usually rode around with the windows down to remedy that problem. He's converted to mass air now.
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
