  • SN95 4.6L Mustang Tech
Help!! flywheel bolts
  • Thread starter Thread starter BlackO3GT
  • Start date Start date Jun 22, 2008
BlackO3GT
54
  • Jun 22, 2008
I was installing my new clutch and flywheel and i stripped one bolt into the crank.
Well like a idiot wasnt paying attention thought the new bolts they give u with the flywheel where the ones for the crank. Started to tighten one down and it started to strip and once i saw that i pulled it back out and the stock one wont tighten into it now. The stock bolt screwed up when i tryed to put it back in. I got a tap and ran the tap through the crank bolt hole and the tap went in ok and held. It looks like it will be ok. The tap goes in further than the bolt goes. I called summit and got the arp studs for the flywheel i hope those will work. They say there longer. Do you guys think that will solve my problem?
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jun 22, 2008
  • Jun 22, 2008
yes, if retapping worked, then you shouldn't have a problem.
TweekedGT
1,274
Alberta
Jun 22, 2008
  • Jun 22, 2008
You'll be good. Just make sure you use the correct torque specs.
F
FullRace
41
  • Jun 22, 2008
Are 4.6 flywheel bolts holes straight through? On my 289 if youd have done that you would have tapped all that **** right into the oil pan.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 22, 2008
  • Jun 22, 2008
the oil pan dosent go near the crank on a 4.6. its a deep skirt block.
AdRock
521
South Texas
Jun 24, 2008
  • Jun 24, 2008
Put all the bolts in with your fingers and thread at least 5 or 6 threads in before you use any tools on them. This ensures that you won't mess up another one.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 25, 2008
  • Jun 25, 2008
I think you will be fine. I would put 2 drops of locktite on it and torue to 75-85 ft lbs.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
