Help! Fox with idle issues
  • Thread starter Thread starter bbarton
  • Start date Start date Sep 11, 2026
bbarton
Kansas City
Sep 11, 2026
  • Sep 11, 2026
Did an oil change last weekend and cleaned the filter. About ten minutes after letting my 93 GT warm up she through a check engine (67 O, 84 O,34 C,66 C). Changed mass air flow sensor, TPS sensor, took EGR off and cleaned. Took EVR off and conducted continuity and it checked out at 73 ohms. Kind of at a loss. Starts and runs but idle is up and down and check engine light is on. Anyone ever had this and can help me with a direction? Not great with a meter. Also, if anyone knows a shop in the Kansas City area that does good work on foxbodys i am all ears. Thanks in advance.
Mcmahst
5 Year Member
Jan 19, 2021
707
287
83
Laguna Woods CA, fort Mohave AZ
Sep 11, 2026
  • Sep 11, 2026
Did you check the vacuum at idle to verify you didn’t create a vacuum leak with your service? Up/down idle is a symptom of vacuum leak. Good luck.
Reactions: keel
AeroCoupe
6,234
4,329
183
Claremore, OK
Sep 11, 2026
  • Sep 11, 2026
Reset the ECU and take it for a drive. Run codes and report back.
Reactions: Mcmahst and General karthief
keel
292
135
53
Seattle, Wa
Sep 11, 2026
  • Sep 11, 2026
Second this. If you changed the air filter then you might have created a leak in the intake tubing after the MAF. The rubber parts of the stock intake tubing can crack with age, especially the ribbed part.
bbarton
Kansas City
Sep 12, 2026
  • Sep 12, 2026
Reset and took for a drive. No change. Pulled vacuum on the egr and it didn’t die or stumble at 5hg. Then turned it off and set vacuum to 10hg but it didn’t leak. Checked hoses and connection, even pulled filter off to see if that was it. Pulled vacuum line off and cleared it with brake clean and ran air through it. I want to say the egr is bad due to it not stumbling or firing when I added vacuum to it but want to confirm before purchasing another damn part.
AeroCoupe
6,234
4,329
183
Claremore, OK
Sep 12, 2026
  • Sep 12, 2026
So after you cleared the codes, took it for a drive, and got it up to operating temperature did you pull the codes again? If so please post up what they are.
bbarton
Kansas City
Sep 12, 2026
  • Sep 12, 2026
They were the same. Just replaced egr and sensor and got rid of 67. Still have 84 O, 34 C and 66 c.
AeroCoupe
6,234
4,329
183
Claremore, OK
Sep 12, 2026
  • Sep 12, 2026
Code 84 - EGR vacuum regulator circuit failure
Post in thread 'Help with code 84 please!'
https://stangnet.com/mustang-forums/threads/help-with-code-84-please.821845/post-8272949
Code 34 - EGR valve position sensor voltage is above the closed limit
Post in thread 'code 34, EGR, Slightly Off Idle'
https://stangnet.com/mustang-forums/threads/code-34-egr-slightly-off-idle.757442/post-7571037
Code 66 - MAF sensor circuit is reporting a voltage below the minimum specified test limit
Post in thread 'Code 66 Help!!!'
https://stangnet.com/mustang-forums/threads/code-66-help.900471/post-9078317
Reactions: Mcmahst
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
