  • SN95 4.6L Mustang Tech
Help! fuel pressure issues...
  • Thread starter Thread starter stang3O2
  • Start date Start date Mar 22, 2007
stang3O2
200
Indiana
Mar 22, 2007
  • Mar 22, 2007
My fuel gauge has always fluttered around 28-32psi while crusing and ideling when I get on it, it will jump up and stay steady but when I let off and push in the clutch it dips real low (below 20psi) for a split second? I had a procharged 00 gt with walbro 255 in tank, 42# injectors and a 40 amp boosta pump.
thanks!
the98stang
2,408
Clovis, CA
Mar 22, 2007
  • Mar 22, 2007
thanks!
Are you sure you have a walbro 255 pump? Those pumps are made for return style fuel systems, and you have a returnless system. I would check the fuel injectors and fuel pump for malfunction. The injectors might be clogged.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
F
Low fuel pressure downstream of fuel rail, good pressure upstream
  • FYWW
  • Feb 29, 2024
2K
SN95 4.6L Mustang Tech May 9, 2026
Cartel
