i was drivig yesterday and my fuel pump just went up stopped turned key forward no fuel pump...towed it home and tested with new relay no go...started testing voltage and i get 12v to the yellow wire on the fuel pump relay but nowhere else also the relay under the dash by the fuse panel wont actuate and gets no power...the nut on the stud holding my fusible links on was loose from vibration i guess cause theyre all new and it was tight but anyway i pulled all the fuses none look bad although i know you cant always tell by looking...which fuse is the fuel pump circuit and which fusible link there are like four or five....i'm sure its just a link or fuse itself cause the pumps brand new the the relay turns it on and the eec relay gets power and works so the ground is there WHAT DO I DOOOOO??????????/
TESTED ALL FUSE LINKS AND GET 12V WITH KEY ON
