Help gas pedal problem.
  • Thread starter Thread starter Black 93 Fox
  • Start date Start date Dec 27, 2003
Black 93 Fox
1,995
Vancouver,Washington
Dec 27, 2003
  • Dec 27, 2003
My gas pedal is being a real PITA. it well get stuck closed. I go to push on it and its like a rock it wont budge. I pushed on the t/b and its hard there to so its not just the pedal. After today's little insedent of almost getting sqwashed by a big ass truck I kinda want to get it fixed. Im thinking cleaning the t/b but how and what do I clean it with? Should I just squirt some starting fluid in there and step on the gas pedal a few times?
Thanks for the info
Black 93 Fox
Q
QBstang87
547
Montgomery Village, Maryland
Dec 27, 2003
  • Dec 27, 2003
adjust the screw under the throttle body that hits the plate and makes the throttle plate actually open a hair. just make that screw touch barely. then reset your tps. cleaning it won't help, but if that screw isn't touching the throttle plate, just barely barely holding it, when the throttle snaps shut it'll stick shut.
Black 93 Fox
1,995
Dec 27, 2003
  • Dec 27, 2003
Ok that might explain it. The other night i had to adjust my idle it was at 1200. So someone told me to turn that screw to get my idle down to 800 were it should be. so i did but i had to turn it alot. and the next day after i did this thats when the pedal started sticking. Also how do i reset my tps?
Black 93 Fox
1,995
Dec 27, 2003
  • Dec 27, 2003
Bump
Q
QBstang87
547
Dec 27, 2003
  • Dec 27, 2003
turn the key on, keep motor off. check voltave with a voltmeter across the green and black wires of the tps, and loosen it if need be and wiggle till you get it (where i like is) between .90 and .95
Q
QBstang87
547
Dec 27, 2003
  • Dec 27, 2003
and dont mess with the screw underneath anymore, if you do, reset the tps again. each adjustment moves the voltage reading on at the tps
Black331Stang
1,485
Long Island, NY
Dec 28, 2003
  • Dec 28, 2003
i personally dont think that with teh butterfly getting stuck closed u can have that much of a stick...it will stick but it will break free, it wont be liek a rock.....if your cable is stock check out ebay or something and get a new one or if the TB is stock time for that 65mm. i would personally borrow a TB form a friend and see. all my experieces with stuck pedals were 90% the TBs fault. good luck.
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
P
1989 turbo fox with microsquirt
  • patsmustang1
  • Aug 14, 2024
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 14, 2024
90sickfox
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
