  • SN95 V6 Mustang Tech
Help Help Help
  • Thread starter Thread starter jconnelly85
  • Start date Start date Jun 18, 2008
J
jconnelly85
  • Jun 18, 2008
My car is dying on the freeway. It did it last friday took it to a shop told the man it seemed like a fuel problem, he checked the pressure and agreed and replaced the fuel pump and filter. Picked the car up today and halfway to my destination it did the same thing.
Now I had been driving 70 for about 2 hours. All of the sudden my car would no accelerate. When I pushed in the pedal it would shudder and drastically slow down. If only holding the pedal just barely in it would go but still not getting up to interstate speed. Push the clutch in and it just cut off. Well taking into account what the mechanic had told me about trying to keep a lot of gas in the tank because it would help cool the fuel pump more, I sat on the side of the interstate for about 15 minutes let it cool off. I got back in and it started just fine and I accelerated fine and drove 2 miles to the next exit got off and filled the tank. I drove the next 30 miles with no problem at all and got home fine.
It only seems like the engine gives up after it has been running for a while because when it did it (fri) the first time I was on my way home and had been driving for about 3 hours.
Could it be the injectors?
Someone mentioned bad egr valve??
I'm not exactly sure what is going on I'm going to call the mechanic tomorrow morning and try and figure it out.
Anyone here have any ideas?
It's a 1995 3.8 manual with 109K.
Thank you in advance,
Jon
98E9GT
110
  • Jun 19, 2008
I would get the MAF tested, my car would do the exact same thing. Turns out I accidentally over oiled my K&N and ruined it, but picked up a used one for 25 from a junk yard.
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
