Help! I can't get the AOD-E off...
KingDiamond
637
Chicago, IL
[NOTE: I'm just bringing back this post because it was lost in the crash, need more input]
I'm trying to do the tranny swap and I can't get the damn AOD-E down.
I removed the following, hopefully this is all that needs to be removed...
6 bellhousing to engine block bolts
2 crossmember to tranny bolts
2 crossmember to frame bolts
crossmember is off
all harnesses disconnected
shift linkage disconnected
4 flywheel to converter bolts are off
driveshaft is off
starter is off
what the hell am I missing? The AOD-E looks like it came out just a tiny bit, maybe a half inch. How much does it have to slide out? We tried wiggling it, pushing it, prying it, and lowering it, and it still won't come out.
Anyone have any ideas?
I would look around the hole where the shifter is located, may be binding up as you try to bring it back. does look like everything is disconnected, should just come off. do you have a jack supporting the AODE, if not try that, pump it up a little to take the weight off, then try sliding back. good luck
:stupid:
sounds like it might just be at too much of an angle and its binding up making it hard to remove
Well I thought it moved out, but I just looked under the car and the bellhousing is still right against the engine block. So the tranny hasn't budged at all after wiggling, shaking, prying, and hammering. I have a 3 ton jack under it and when we were trying to remove it, it was pretty level, and we tried lowering it a bit too, and all it does is lower the engine with it. It's about a 1/2 inch from the shifter area so I don't think it's binding either. I'm starting to think I missed a bolt somewhere but I triple checked and there are no bolts left.
When we were removing the driveshaft, it had been fused by rust to the pinion. We couldn't get it to budge at all until PB blaster set in for a day. I'm starting to think that maybe the same thing is going on here?
The dowell pins are probably holding it. I would try driving something between the block and trans where the dowell pins are. Do both sides a little at a time to keep it from binding.
