Fox Help!!!! I Sit Taller In My Car Now That I Replaced My Interior!!!
newbie1979
22
I just replaced seat foam and upholstery from TMI. It seems I sit higher now is this a common problem? I have an 89 GT Convertible . When I sit up my eyes are parallel with the top of the wind sheild. I am a 5'10 190 male. Did I do something wrong?
Just had the same problem when we changed the foam in the seat of the Cobra. We ended up consulting an interior shop, and they told us some disheartening news. The TMI stuff is pretty low grade, and they don't use it. They took the seat back apart and trimmed a lot of the foam off, and it was better, but not great. They said the only way to really fix it is to replace the TMI foam with higher grade stuff.
Kurt
Reactions: newbie1979
Something along those lines. It's too dense, and it's not cut well, so it sits too high. I'm not sure how it is on a Foxbody, but on an SN, the leather is glued to the foam. The TMI stuff is only set up for hog ties, which don't work, because there is no where to hog tie on the leather. Is your stuff hog tied down?
Kurt
Im really upset because I was going to just order the http://www.latemodelrestoration.com...ible-Corbeau-Black-GTs-2-Interior-Upgrade-Kit . Instead I replaced all the upholstery and foam . I had a heck of a time getting the upholstery on and when I did the stupid cheap plastic zippers broke. I took it to the local upholstery shop and he gave me a look like this stuff is junk. He actually put his own zippers on. Not even trying to use the zipper on the Passenger seat. I'm just pissed cuz I cant see out of the car correctly now:(
If I can make a suggestion. Why not contact TMI about this issue before coming here?
Reactions: elarm1 and madspeed
Im really upset because I was going to just order the http://www.latemodelrestoration.com...ible-Corbeau-Black-GTs-2-Interior-Upgrade-Kit . Instead I replaced all the upholstery and foam . I had a heck of a time getting the upholstery on and when I did the stupid cheap plastic zippers broke. I took it to the local upholstery shop and he gave me a look like this stuff is junk. He actually put his own zippers on. Not even trying to use the zipper on the Passenger seat. I'm just ****ed cuz I cant see out of the car correctly now:(
Newbs - LMR sells both our upholstery and our direct competitors (cheaper) upholstery. Can you confirm 100% that the upholstery you received came in box with a large red, TMI logo on both sides? Our upholstery will also have a TMI tag on the inside of all of the upholstery pieces.
Lets start there- check it out and let me know.
Thanks,
