Help! Ignition problem
  • Thread starter Thread starter jtramo
  • Start date Start date Jul 13, 2005
J
jtramo
  • Jul 13, 2005
I have a 65 289 Mustang vert. I just finished up headers and put the plus wires back in and it runs like crap on maybe 4 cyl. I remember when i took the wires off they didnt seem to be in the correct order but failed to mark them, thinking "ill fix em the right way." Well i put them in as the book says and it has gone to poop. Any ideas why it would run better with the plus wires not in the factory order??? Help!!
krash kendall
1,258
Aldergrove, B.C. Canada
Jul 13, 2005
  • Jul 13, 2005
Your distributor may not be engaged in the optimum position resulting in a different plug #1 position. Find top dead center (intake and exhaust valves closed on piston #1 with piston at top of cylinder, timing mark at 0 deg.) then take the distributor cap off and see where the rotor is pointing. This is where the #1 plug wire should be. Then follow around with the correct firing order.
Or - pull the distributor at this point and re-index it so it's pointing where the book tells you and then re-wire it.
F
Fomocohipo
128
  • Jul 13, 2005
oops wrong thread, but similar...
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Tuesday at 12:38 PM
DadLife0724
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
