Help!! I'm In Electrical Hell!!
jpk
marysville,wa usa
I recently traded a ford focus for a 1989 5.0 lx convert. I thought i got the better part of the deal because both cars needed work. The problem is when I put in the battery one fuse gets super hot and also a group of wires that go to the ecu. The previous owner had replace the wiring loom and there is a ton of wires that don't match up ! i have a wiring diagram but its like greek to me. Any advice??
If you can't read wiring diagrams, you need to either learn how or find a friend who can.
Find the problem wire or circuit using the diagrams below.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
