Help kill ELECTRICAL GREMLIN! part 2
  • Thread starter Thread starter Opal50
  • Start date Start date Jul 23, 2007
O
Opal50
21
  • Jul 23, 2007
Ok, here was my original problem:
http://forums.stangnet.com/showthread.php?t=710603
Here's an update:
I've tried swapping the coil, wires, distributor cap, rotor, distributor, and ignition module. All have failed at solving the problem. My last attempt was the distributor due to the notorious PIP sensor, but no cigar.
Here's where I get confused:
I replaced the distributor and put the new one in to essentially the exact same position as the original. The car wouldn't start. There was no spark. After a few minutes of head scratching, I removed the SPOUT connector and it fired right up. Plugged the SPOUT connector back in, while running, shut the car off and restarted, no problem. Took the car for a spin, died a mile down the road like before. Took the SPOUT out again, fired right up and drove home without it in, running like crap. What's going on here? Please help.
Thanks
94 GT, manual
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 24, 2007
  • Jul 24, 2007
The pip sensor in the replacement distributor is bad.
O
Opal50
21
  • Jul 24, 2007
Are you kidding?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 24, 2007
  • Jul 24, 2007
Opal50 said:
Are you kidding?
No.
Send me your email address and I will send you two PDF articles by Wells, the folks that make TFI & PIP assemblies that describe your problem.
T
TorqueO
Stratford,CT
Jul 24, 2007
  • Jul 24, 2007
Found him...lol
O
Opal50
21
  • Jul 30, 2007
Just to let you guys know, it ended up being the PIP sensor. The one in the new distributor was bad. I talked to the guy at Autozone and he said they don't even replace those when they rebuild them. Anyway just thought I should post some results. Thanks for all the help guys.
HISSIN50
34
129
Jul 30, 2007
  • Jul 30, 2007
You're right - if the PIP bench tests ok, they often leave it.
A hint to see if a reman'd dizzy has a new PIP is to look for an unused roll pin hole. They often wont bother to line the old holes up and just punch a new one.
Glad to hear you got it fixed. And nice work by JR to diagnose it, no muss no fuss.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
