Ok I'm getting close to being ready to start putting my first engine togather. I am trying to put togather a list of "supporting" parts and am starting to feel like I'm a little over my head. First off, here is what I have starting from top to bottom:
Carb
Intake
Heads
Rockers
Pushrods
Roller Lifters (with dogbones and spider)
Cam (and bearings)
Pistons (with rings and pins)
Remachined Rods (and bearings)
Remachined Crank (and bearings)
Block with freeze plugs and machine work
Now, parts I know I need:
Air cleaner
Valve covers
Distributor (with plugs, wires, and a coil)
Fuel pump
Water pump
Oil pump and pickup
Oil pan
Timing chain and cover
Alternator
Belt and pullies
Harmonic balancer
Flywheel
Gaskets.
Anything eles? Do I need a front or rear sup oil pan? please let me know what you think
Tyler
Carb
Intake
Heads
Rockers
Pushrods
Cam (and bearings)
Air cleaner
Valve covers
Fuel pump
Water pump
Oil pump and pickup
Oil pan
Alternator
Belt and pullies
Harmonic balancer
Flywheel
Gaskets.
Tyler
