57fairlane
Swede958 said:If your's alt bracket doesn't work... find a peice of steel or alluminum tubing large enough diameter for a bold to the outer most cylinder head point to go through. I forget exactly where but you can order adjustment rods (threaded rod with to heim joints on the end) and use that for the tensioner and you got yourself an alt bracket.... just cut the tubing to size.
You should market these . . . . just don't tell march
:Zip2:
