Help Me Fix my AC
  • Thread starter Thread starter 84blkstang
  • Start date Start date Jul 20, 2005
84blkstang
544
Springfield MO
Jul 20, 2005
  • Jul 20, 2005
I have made a few threads before about fixing my AC system. The old system that was on the car had a line that was cut into, it was the one going from the firewall to the condensor. the two other AC lines (compressor) were fine. I robbed all the lines condensor, evaportor and everything else off a 88 GT, even the heater core box. Tomorrow i want to install everything, is there anythign i need to replace besides the O-rings? The i will take the car to a shop and have it vaccumed out then i will buy the R134 and put it in myself since it is pretty simple. Now to the oil where do it get it? Can I get the right stuff at o rileys or walmart or somthing., I need some guidance here since i have never done this before. I want to do this once and do it right, Thanks
PuterAmI
513
Madison, Alabama
Jul 20, 2005
  • Jul 20, 2005
http://www.veryuseful.com/mustang/tech/general/R12-to-R134A-Conversion.html
84blkstang
544
Springfield MO
Jul 20, 2005
  • Jul 20, 2005
Does the rest of my plan of attack sound ok?
PuterAmI
513
Madison, Alabama
Jul 20, 2005
  • Jul 20, 2005
Have the shop vacuum and charge. It will cost a little more, put they will be charging into a vacuum as well as using pressures and vent temps to adjust the amount of refrigerant.
84blkstang
544
Springfield MO
Jul 20, 2005
  • Jul 20, 2005
ok i called a few shops and on average they want 40 per lb of freon to vaccume and charge does this sound right?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 20, 2005
  • Jul 20, 2005
$40/lb is assuming that they'll be putting R12 back into the system, since that's what your car was originally equipped with. If you're doing a complete swap, and 134a conversion, the price should go down drastically from there. It should only take a couple cans of 134a + 8oz of PAG oil to charge the system, if it's the same as on my 95. A/C is nice to have, I wouldn't ever remove it from my car, so it kinda sucks that the previous owner did to yours
T
Traitor5150
24
  • Jul 20, 2005
I know at the shop I work at i think we get $16 a pound for freon
84blkstang
544
Springfield MO
Jul 20, 2005
  • Jul 20, 2005
so is 40 too high?
sgarlic
3,085
Jul 21, 2005
  • Jul 21, 2005
It's 25 per lb for r134a here in Tucson.. but everybody needs a/c work here.
PuterAmI
513
Madison, Alabama
Jul 21, 2005
#10
  • Jul 21, 2005
  • #10
Nope.
Explain that you are converted to R134A and ask again.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
M
  • mnky99
  • Sep 5, 2025
mnky99
M
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
Gen 3 Coyote Swap Variable Displacement AC Compressor Troubleshooting
  • rydnoryder
  • Jun 12, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jun 16, 2025
rydnoryder
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
