Help me hook up!
Trav4011
174
What are you 5-600whp guys running out back in terms of suspension/tire combos? I'm looking to tackle my suspension this spring, and I need some tips/pointers. I'm not looking to back-half the car or anything.. just want to be able to drive it to the track, toss the slicks on, and then drive it home after. I have currently have the following driveline mods..
Viper-Spec T56
Spec 3.5 (4 puck sprung hub and heavy duty pressure plate)
Aluminum flywheel
Cobra driveshaft
Auburn diff with 4.10's and Moser axles
Everything else out back is stock.. I have a Novi 2000/built motor combo, and will be making somewhere in the neighborhood of 550-600whp.
I bought I pair of used Mt 26x10x15 slicks off of ebay and 2 new steel 15" rims from summit, all together I have about 200 invested.
The rear build is going to be 31 spline alloy usa axles
31 spline rebuilt ford trac lock from an explorer with extra clutches
replacing all seals and bearings
welding the axel tubes and torque boxes
3.73 gears
I should be around 500 after my next tune.
I have a small parts store in my living room lol.
