Help Me Please
  • Thread starter Thread starter haleygotastang
  • Start date Start date Apr 18, 2005
H
haleygotastang
  • Apr 18, 2005
I just did the plugs and changed the oil in the car... b/c I just bought it... I gapped the plugs at 45... It was fine yesterday but then today started sputtering.. if you rev it while its in neutral ... it sputters like its missing a little.. but the idle is fine...?? plugs??? control module???? what could cause this...
oh yeah its an 88 gt 5.0 w/intake h pipe w/no cats and dual flows
BlownInjected
39
Glendora,Ca
Apr 18, 2005
  • Apr 18, 2005
maybe you crossed an ignition wire
H
haleygotastang
  • Apr 18, 2005
I checked all the wires and such and they are all fine.... I dunno what it could be... did I gap the plugs right??? is 45 too much or too little.. they are auto lite...
D
Daggar
3,902
  • Apr 18, 2005
It sounds as if you might have sprung a vaccum leak or your EGR is acting up.
rd
3,316
63
109
Ocean Springs MS
Apr 18, 2005
  • Apr 18, 2005
Pull the plugs and make sure one is not broken, or has the porcelin cracked.
See if you can isolate the missing cylinder by putting a timing light on each plug wire.
My guess is that the stress from changing the plugs killed one of the wires, and when it needs to carry heavy spark current, it fails.
Y
yogi_stvl
53
Sacramento
Apr 18, 2005
  • Apr 18, 2005
did you clean the engine with a engine degreaser? i did that and then washed it off but i got a little moisture under my distributer cap... sputtered.
HISSIN50
34
129
Apr 18, 2005
  • Apr 18, 2005
i would yank the codes and see what gives. also run the cylinder balance test while doing so. if the balance test reveals nothing, carefully (do at your own risk) pull one plug wire at a time to see if you can isolate the bad cylinder.
good luck.
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
D
2.3l mustang hard starts and bogs and stalls when you floor it from idle
  • declan
  • Feb 19, 2025
  • 2.3L (N/A & Turbo) Tech
2K
2.3L (N/A & Turbo) Tech Feb 28, 2025
declan
D
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
