First i'll start off with my goals and intended usage of the car, then i'll get into what I plan on using.
I want to do a 10.5-10.8:1 compression 347 that makes around 400rwhp/400+tq and won't have to be shifted past 6200 rpm. I want a killer torque monster as well. I've seen mild (sub 400rwhp) 347's doing like 350ft-lbs by 2400rpm and thats what I want! This is NOT a race car and probably won't see the track because our local track got shut down. Its just gonna be a fast weekend cruiser that I could pick the girlfriend up in and go to the movies or just play around on the street and have fun, NOT a track only car that see's high rpm. I will be having Erik K from horsepower engineering do the shortblock!
Now on to the parts I plan on using. This will be a stock block. I'll be using an eagle rotating assembly. Cast steel crank, I beam rods and JE forged pistons for trickflow TW heads. I will be using a set of trickflow TW heads that are milled to 57.6cc and have good valve springs in them that I got from ed curtis. I plan on using a TFS R intake with a 75mm TB, 80mm mass air and 30lb injectors. I have 1 5/8" longtubes now, but will upgrade to 1 3/4". I haven't decided on the cam. It will be a custom from either jay allen or ed or possibly an AFM cam if it can get me my goals. Most likely a jay allen cam. Money is an issue so I can't afford the "best of everything". I dont want to port my heads, thats too much money and I can't swing that. I might check into a local shop though to get port work prices just to see. I'll also be using a 28oz romac and a 28oz ford flywheel. I have to check with Erik on the compression with those JE pistons.
What do you guys think about my planned combination? Im sure you all have idea's on how to make more power, but keep in mind this is JUST a pump gas street car that gets driven on weekends and isnt raced unless a friend wants to play.
Mike
Mike
