Help me solve this problem
Chetly
117
I just installed a used trannty and a ram clutch. I went to start my car and roll it out of the garage, the car bogs down when you let the clutch off. I tried driving back into the garage and the car bogs down. You can feel it hit the friction point, then you gas and go, and it stalls out. If you give it alot of gas it will moves, but at low speeds feathering the clutch it boggs down. SOmeone told my my timing is to retarded and thats why. Any other suggestions, has anyone else ever experiecned this. Thanks
Look for loose plug wires, loose or broken vacuum lines.
Everything clean and tight, Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
