help me spend
lex2lo
14
ok guys roughly 2k budget what do i do first?
mods i have already
3.73, full exhaust including headers,
so what next heads, cam etc.
the few questions i had are like what size mass air and throttle body will fit the march cold air in fender. lph fuel pump with what size injectors? heads with wich cam and rocker arms and springs what are some good combos basically. im doing all heads up, when i blow the bottom end ill go stroker:D so for know just all bolt ons
If you shop really really well, you can get a full h/c/i setup for that much.
The depending factor will be how much you pay for the heads.
Keep an eye out for used Twisted wedges, edelbrock rpms, gt40x and afr 165's (although the afrs are a long shot). $800 (used)
A pro m(old pro m) or pmas meter calibrated for 24's.
65 or 70mm TB and spacer.
Other things you'll need:
Arp head bolts
Ford racing timing chain
Ford racing water pump
A cam
Roller rockers
A full set of gaskets
Pushrods
155 or bigger pump
For an intake i'd consider a gt40 or cobra, gt40 being my preference, but the cobra is as good but noticeably cheaper.
