Help me with a mod path!!
  • Thread starter Thread starter needafox
  • Start date Start date Apr 12, 2006
N
needafox
9
  • Apr 12, 2006
I am looking for a good mod path to follow. I just purchased my first 5.0. It's an 89' GT. The exterior is in great shape, it's just needs some muscle to back it up. Right now the car has:
bbk shorty headers
catless h pipe
flowmaster mufflers
underdrive pulleys
richmond 3.73's
auburn posi unit
and edelbrock upper and lower intakes.
I need some recommendation on what to do next. I am not really working with a tight budget, but I would still like to keep the cost pretty reasonable. The ultimate goal for the car is to have a nice mid to low 12sec streetable weekend racer. Any suggestions are welcome.
J
jjd975
4,236
louisville,kentucky
Apr 12, 2006
  • Apr 12, 2006
Tons of ways to go.
Give a budget to us. Against nitrous?
J
JunkyardTurbos
  • Apr 12, 2006
bbk shorty headers
catless h pipe
flowmaster mufflers
underdrive pulleys
richmond 3.73's
auburn posi unit
GT40 intake, AFR heads, B303 cam, 70mm TB, mass air sensor + 36lb/hr injectors etc.
-or-
Turbocharge what you have right now. My 94 GT went 12.50 on the stock motor with a T-70 and intercooler. The only mods were an FMU, fuel pump and MSD with boost retard. Later I went with a 355 stroker, Twisted Wedge heads, turbo cam, Accel DFI, and on and on...
N
needafox
9
  • Apr 12, 2006
I would like to stay away from nitrous if at all possible.
The turbo idea is definitely something I have been thinkingabout as I just came from a 2004 STi, before that a 2002 WRX, and Eclipe GSX
RBRANDX
110
Myrtle Beach, SC
Apr 12, 2006
  • Apr 12, 2006
Turbo/SC is a good way to go to make a ton of power off the bat..But I would also consider laying the ground work out first, Good heads, cam, port the edel intake, fuel sys., subframe connectors, good adj. upper/lower controll arms, etc...etc...That way when it comes time to add the Turbo/sc/nitrous, you will be able to take full advantage of it, and put that power to the pavement! As they say...cant build a mansion on a toothpick foundation! Good luck
N
needafox
9
  • Apr 12, 2006
I would def. like to do some supporting mods before I go ahead and add some sort of forced induction. Would going to to a 306 or something like that help me to get down into the low or mid 12's without adding a sc/tc?
soontobefastfox
275
Troy, Michigan
Apr 12, 2006
  • Apr 12, 2006
306 would be good, but why not buy a stroker kit and stroker clearence it yourself. 306 forged rotating assemblies are as much as 331 or 347 stroker kits. So I don't see why you wouldn't want go with a stroker it. My advice is build from the bottom up, any good engine builder will tell you that.
J
jjd975
4,236
louisville,kentucky
Apr 12, 2006
  • Apr 12, 2006
You can add some heads and a cam and have 12 second power.
Some TFS or AFR heads and the right cam is all it takes.
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Fox Build ideas for the 'Hudson Heap' (87 GT)
  • MadSquirrelTech
  • Sep 19, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2023
MadSquirrelTech
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Progress Thread finishing touches on my stroker build
  • doobismaximus
  • Jul 2, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2021
nickyb
K
Project Ideas (2006 S197)
  • Kitsune187
  • Apr 22, 2019
2005 - 2014 S-197 Mustang -General/Talk- Apr 22, 2019
Kitsune187
K
