HELP - Melling pump interference
  • Thread starter Thread starter Ocalafox
  • Start date Start date Dec 23, 2008
O
Ocalafox
266
sunny central FL
Dec 23, 2008
  • Dec 23, 2008
Has anyone experienced interference when using a Melling high volume oil pump? I half installed my oil pan (5 lb torque on bolts) then removed it and could see where one of the pump cover bolts was beginning to gouge into the bottom of the oil pan (stock pan). All advice is appreciated, switch to aftermarket pan, radius bolt head with a file? I wasn't expecting this, I did verify the distance from pick-up to pan, 5/16".
Thanks in advance,
vann
vristang
4,933
101
124
Seattle
Dec 23, 2008
  • Dec 23, 2008
Seems odd...
verify the part numbers on the pump are for a 302, and not a 351w...???
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 23, 2008
  • Dec 23, 2008
I had the same problem since the Melling pumps are a big cast iron honker of a pump. I heated the pan with a MAP torch and dimpled it with a ball pien hammer. After I got the required clearance, I heated it again to stress relieve the hammered area of the oil pan.
O
Ocalafox
266
sunny central FL
Dec 23, 2008
  • Dec 23, 2008
Thanks JR, I'll prolly go that route. As far as part number the box is M-68HV which is correct to Jegs catalog. I'll verify ID on the pump.
Thanks,
vann
rd
3,316
63
109
Ocean Springs MS
Dec 24, 2008
  • Dec 24, 2008
If you had a gasket in place and it hit, yes, you need to provide some relief.
Just went through this on another vehicle, and with the gasket, it all seemed to clear, so on it went.
O
Ocalafox
266
sunny central FL
Dec 25, 2008
  • Dec 25, 2008
Thanks guys, I "dimpled" the pan for clearence and filed the bolt for additional clearence. Yes, it initially hit with the 1 piece fel-pro blue gasket inplace. Now that that's behind me I'm trying to locate TDC with a "POS" streetdamper. Of course it doesn't line up with the stock 5.0 timing indicator. Oh well, if it was simple Mattel would make 'um. Anyway Merry Christmas and that's for the advice this past year. I'll finally have my 347 (and cleaned engine bay) running sometine in Janurary.
vann
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
