  • 1994 - 1995 Specific Tech
Help my '88 Cougar!!!
  • Thread starter Thread starter Badder Adder
  • Start date Start date May 3, 2004
Badder Adder
268
Hazleton, PA
May 3, 2004
  • May 3, 2004
I know this isn't a mustang, but I need help... My daily driver '88 Cougar with the 3.8 V-6 is giving me fits. It has the nasty habit of dying out at seemingly random times. You can be driving along no problem... with good power and mileage and everything and then BAM it just shuts right off instantly and won't restart. However, once it has cooled down it restarts no problem.
So, my first guess was the notorious ignition module mounted on the radiator support. I switched that out yesterday and same result. All I can figure is that something electric is failing once it warms up. Any ideas???
F
fastf50rd
720
mass.
May 3, 2004
  • May 3, 2004
I'd check the coil, and ground points for your battery. Also check into the wires goin to your alternator.
HtownGT
544
Houston
May 3, 2004
  • May 3, 2004
same thing happened with me, i believe it was a bad heat sync, its like a silver box on the passenger side under the intake tube in the stang.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
D
Need help for my PCM Mach1
  • Danaololo
  • Jul 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 30, 2025
Danaololo
D
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
