Need some help guys... For some odd reason, my ignition is sticking.. I mean all of a sudden it just keeps turning with the key on the off position and even after the car has started
. I've changed the battery and starter is practically new. The only way to stop it is by disconnecting my ground on the battery.. It's to where it's turning all the time now so my car is outside sitting with the battery disconnected.. I have an MSD 6al, crane cams fireball, and stock distributor.. The usual stuff really.. I'm at a loss and need help badly. Any advice is direly appreciated cause this car is my means of transportation... I've also disconnected my switch to see if it might be the culprit and it seems to be ok unless i'm just not disconnecting something I might have missed....HELP PLEASE!!!
