Help needed ASAP
STP72
109
Hey guys, I have an 88 LX 5.0 and the heater core is leaking bad. I need to bypass it to get me mobile as I am stranded. How do I bypass it for a temp fix untill I get to replace it.
Thanks
The hose sizes are different between the feed hose and return hose. One hose is 5/8" diameter and the other is 3/4" diameter. The easy fix is Home Depot or Lowes will have a black plastic hose barb coupler that is 5/8" diameter on one end and 3/4" diameter on the other. Use this hose coupler to join the two hoses.
I bypassed the heater core on a friend's LX. I was able to force the 5/8" i.d. hose over the larger tube. The hose was pretty warm at the time and that helped it give a bit.
You could probably use a hose clamp to keep the larger hose tight on the smaller tube, but that would be a very temporary fix.
Jrichker's plan is the best, long-term solution.
