RioRed95Cobra
- Apr 7, 2017
- 180
- 17
- 28
That sounds... bad. I just did a swap from a v6 to my '95 cobra setup.. and it ran like this for a bit.. i'd put money on your distributor or timing..
I went through the gauntlet too.. replaced IAC, ECT, IAT, cleaned tps, reset, did idle reset, went through 2 different lightning MAF's, new everything.. it was the goddamn plug wires. Yes my dizzy was bad too, but the whole issue stemmed from a bad wire that was arcing.
This sounds a lot more like fuel pressure, timing, or plugs being fouled to hell. What do the plugs look like? That sounds like
.. You should def. check timing.. fuel pressure.. then if your plugs look ok.. go from there.
I'd bet something is WAYYYYY off by the sounds of it..
.. You should def. check timing.. fuel pressure.. then if your plugs look ok.. go from there. I'd bet something is WAYYYYY off by the sounds of it..
okay thx guys i will check everything yall told me about when i get home. the odd thing is i only seen like 1... MAYBE 2 ground straps so far and one went from the battery then to the front brace by the radiator by the hood stopper. i didnt see one from the head to the firewall. so i got alot of searching to do on the motor for those ground straps
