Roush Help Needed Once Again!!!!!!
saleensc281
184
Ok here is the issue, for some reason the rubber inserts on the Saleen Brake and Clutch Cables keep coming off, Ive managed to lose one and find the other. Is there anywhere I can get the rubber insert or do I need a whole new pedal pads???? Can anyone point me the right direction as to what to do and to where to find them???? Thanks alot!!!!!! Another question to is how good is the new SCT Flash Tuner called XCal, I believe, is it just about as good as a dyno or not????? Would you recommend the XCal or a SCT chip and tune??? Again thanks for the help!!!!! Jake :shrug:
I think, SCT makes the Xcalibrator, and yes it's a nice setup. To do it right you need to buy the xcalibrator (I think it's now an XCalibrator II) and have a Performance shop with a dyno program it for you.
The only way to tune your Saleen SC281 is on a Dyno. I have had first hand experience from not going to a Dyno and then going to one. Also my experience
with SCT with a Saleen Power Flash was not positive we coudn't get the car dialed in. Go with Diablo Revolution chip dialed in with the predator. I am getting the performance and safety margins needed after adding the Chicane 66mm Pulley. I also have an upgraded fuel pump 255lph.
Barry
2000 Saleen SC281 # 0388
