Help needed
  • Thread starter Thread starter Cobain03
  • Start date Start date Feb 6, 2006
Cobain03
996
Lexington, Ky
Feb 6, 2006
  • Feb 6, 2006
i recently got done instlaling my new engine and took her for a test drive. i went to stop, and the pedal goes almost to the floor. i've been told that this is a vacuum problem because of the bigger then stock cam. whats the fix?
iskwezm
4,159
20
79
Rowland Heights,California
Feb 6, 2006
  • Feb 6, 2006
your cam isnt that big, is the vac hose hooked up???Fluid???leak????
BDT 1967
91
Wichita KS
Feb 6, 2006
  • Feb 6, 2006
Ya for sure your cams cant be that big. I would think a leak, or something along that line.
NasaGT
1,993
Virginia
Feb 6, 2006
  • Feb 6, 2006
Leak? Air in the lines?
Does the pedal pressure come up if you pump the pedal?
Cobain03
996
Lexington, Ky
Feb 6, 2006
  • Feb 6, 2006
how many lines are there? the fluid level is good. should i try pumping the brakes for a lil bit to get everything back in sync?
geostang351
946
Danb., CT
Feb 6, 2006
  • Feb 6, 2006
I had the same problem. I bled the brakes and it helped. Amazing how corroded the fluid gets in 5 yrs.!
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Feb 6, 2006
  • Feb 6, 2006
I had a similar problem only to find out that the adjustment cable had slipped off one of the rear drum brakes
69Rcode_Mach1
1,473
Salt Lake City, Utah
Feb 7, 2006
  • Feb 7, 2006
I would try bleeding those brakes first, that should help. Then check to make sure the pushrod is hooked properly to the pedal, and not just dangling in place from the boot.
Cobain03
996
Lexington, Ky
Feb 7, 2006
  • Feb 7, 2006
i should add, that if the front wheels are jacke din the air, they are totally free flowing. no friction from the brakes.
iskwezm
4,159
20
79
Feb 7, 2006
#10
  • Feb 7, 2006
  • #10
thats not a bad thing if you drag racing........ , but i would bleed the system and adjust the brakes all around
Dark Knight
2,578
Chandler, Az.
Feb 8, 2006
#11
  • Feb 8, 2006
  • #11
Sounds like a bad master cylinder.. 'specially if they're full of fluid and you havent touched anything else.. check the wheel cylinders too, just in case..
The lack of vacum would make it harder to stop because you wouldnt have the power assist...
latamud
791
Tampa, FL
Feb 8, 2006
#12
  • Feb 8, 2006
  • #12
I agree with bleeding the brakes. You can't go wrong there. But you just swapped engines, and they worked before? It sounds like a vacuum leak.
Cobain03
996
Lexington, Ky
Feb 8, 2006
#13
  • Feb 8, 2006
  • #13
we got around to adjusting the brakes, and found that the driver rear had brake fluid leaking out of it. so im guessing a new wheel cylinder will be the fix.
Edbert
3,548
32
109
Austin TX
Feb 8, 2006
#14
  • Feb 8, 2006
  • #14
Bleeding the brakes at the wheels wont help if there is air in the MC, try a bench bleed of it too while you are at it.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
