Help needed
Cobain03
996
Lexington, Ky
i recently got done instlaling my new engine and took her for a test drive. i went to stop, and the pedal goes almost to the floor. i've been told that this is a vacuum problem because of the bigger then stock cam. whats the fix?
Sounds like a bad master cylinder.. 'specially if they're full of fluid and you havent touched anything else.. check the wheel cylinders too, just in case..
The lack of vacum would make it harder to stop because you wouldnt have the power assist...
