No Overdrive?
Most likely something you can't just fix at home.
The trans has to be pulled apart, and the OD band will need to be replaced. Usually the first thing to go in an AOD. The band gets burned and then has no holding power. If the band is toast, most probably the rest of the trans is too.
So, long story short. Start saving your cash for a new/rebuilt trans.
You can still drive it as is, but be ready.
