HELP:No Smog Pump, Causing low end missing?
  • Thread starter Thread starter 90stangLX302
  • Start date Start date May 23, 2004
9
90stangLX302
76
Good ol' Bellaire Ohio
May 23, 2004
  • May 23, 2004
About 3 days after i removed my smog pump, my car started missing at low end rpm's 0-2000. I took it to a local shop and they said its was caused by my smog pump being removed and throwing trouble code from the o2 sensors. They reset my computer and it was good for about 3 days, then it started doing it agian. Any suggestions on what could be causing it, please drop them in. Thanks
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 23, 2004
  • May 23, 2004
What? That was absolute BS. The mechanic was just telling you that because he couldn't figure it out so he wanted to give an answer.
The O2's and smog pump and EGR are totally different systems. All the o2's do is measure the amount of o2 in the exaust.
The EGR (exaust gas recirculation) takes exaust gasses and puts them back into the intake. This reduces combustion chamber temps reducing NOX emmisions. Now the system is controlled by the EGR solonoid, which if the EGR valve or solonoid was malfunctioning it could be opening the EGR at the wrong time. The EGR is supposed to only be open durring cruise and deaccerleration, if it is open durring load or idle it will cause a bad miss. Try disconnecting the EGR valve and see if that makes any difference.
The smog pump is just an air pump. It is an example of 1980's emmisions technology, it is supposed to feed air to the cats to make them more efficient. That is why there are two lines, one to the 2 lower cats and one to the back of the heads. The one to the back of the heads feeds air into the exaust ports themselves, for the 2 upper cats. There are vaccume controlled solonoids which tell it when to open and close.
For a low end miss, check plugs and wires first, as well as any vaccume leaks. I just never have heard of the air pump deleted causeing a miss.
9
90stangLX302
76
May 23, 2004
  • May 23, 2004
The thing that stumped me was why it didnt do it after the computer was reset for about 3 days
9
90stangLX302
76
May 25, 2004
  • May 25, 2004
I tried plugs, wires, distributor cap and rotor still missing badly
W
wisconsinboy
78
eau claire wisconsin
May 25, 2004
  • May 25, 2004
yah i got my smog out and my car runs mint after the rebuild so tell the mechanic to smoke a pole
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
