P pureplayaz9878 New Member Dec 23, 2005 5 0 1 Ne Apr 8, 2012 #1 Apr 8, 2012 #1 02 mustang gt stock is automatic when i go to start it dies well not dies but dont start kind of jugs and dies then i try again and push the gas down to get it runnin and fine never dies or anything. but takes few times every time i shut it off
Superhereaux chicks make me feel inadequate Founding Member Jul 30, 2002 538 3 59 South Texas Apr 8, 2012 #2 Apr 8, 2012 #2 Do this next time you head out in the morning or vehicle has been sitting for at least 6 hours or so. Turn the ignition to 'Run', listen for the fuel pump to prime for a second or two, then turn ignition to off. Repeat 2 or 3 times Finally, crank up the car. If it fires right up (or at least quicker) I'd suspect the fuel pump. Also, last time you changed fuel filter?
P pureplayaz9878 New Member Dec 23, 2005 5 0 1 Ne Apr 8, 2012 #3 Apr 8, 2012 #3 i tried do that but still started the same runs great after starts
4 40oz Member Jan 9, 2006 499 3 18 Minneapolis Apr 11, 2012 #4 Apr 11, 2012 #4 How many miles are on the car? I'd change the plugs. It probably could use a new fuel filter as well but I doubt that'd fix the problem by itself.
P pureplayaz9878 New Member Dec 23, 2005 5 0 1 Ne Apr 28, 2012 #5 Apr 28, 2012 #5 It has 93000 so ya pry use plugs for sure only had for month so far so don't know much bout car
