it sprays out from between your oil fiter and the housing? check to make sure that there's not the old gasket stuck on the housing.
or is it an actual hole?
Doubled up gaskets or hole in body of filter. Either way you need to take the filter off.
getting tobe a common problem. could be the filter to block gasket, or the filter housing or the ehgine oil cooler (if equiped) over a period of time electrloysis cause the 2 metals to corrode, esp if one does not change there coolant often enough. on cars that are equiped wth the engine oil cooler there is a small "bleed" hole in the housing which is suppose to leak when trouble arises.
Is it coming out around the filter somewhere or do you see a hole with oil squirting out? Clean the area good with a rag (& brakekleen if you have some) then observe. If it's near the filter, it could be as most people have mentioned with the gaskets. I have actually seen a filter that was brand new with NO gasket.
Yeah it is getting somewhat common, mine went on my 01 it just cracked one day and started seeping..
Check for these easy fixes first.. If it's not one of those swapping the filter adapter/oil cooler is easy to do.
It has the spacing between the filter. Thats the part with the weep hole that is squirting the oil out when i start the car.
well thats the engine oil cooler and its prob rotted-out. now there are 2 O-rings between the oil cooler and the housing on the block, you could try and replace them first and see if that helps.
if not you'll still have 2 options. keep the oil cooler set-up(buy another one) or get the non oil cooler adapter on the block and just delete it.
Thanks, I'll give that a try. Do you know where I can get a cooler for $200? Ford told me $280.
Yeah you already have been talking to the guy that can help you.. randy is a parts manager at a ford dealer, I bet he will be more than happy to help you out..
thanks MikeYeah it is getting somewhat common, mine went on my 01 it just cracked one day and started seeping..
What cracked? the oil filter housing? because the bottom of my car is covered in oil and I have never been able to find the damn leak. but its always around the filter. Covers the steering rack in oil.
