Help on 5lug axles.....
  • Thread starter Thread starter 808Gt
  • Start date Start date Jan 15, 2006
808Gt
115
Hawaii
Jan 15, 2006
  • Jan 15, 2006
I am changing my rear axles to ranger 5-lug axles this week and had a question about the lube and friction modifier..... My question is when I finish installing the axles on the rear end, and re-installing the cover How or when and were do you put the lube oil in and friction modifier?? and do you add the lud and friction modifier together??
rd
3,316
63
109
Ocean Springs MS
Jan 15, 2006
  • Jan 15, 2006
You put the cover back on, using RTV as a gasket, and add oil through the fill plug on the drivers side front.
I would make sure you can get the plug out before you start. It usually takes a 3/8 drive socket extension.
I usually put the oil in first and then add the friction modifier in the middle or at the end.
It is sometimes a pain to fill, I have ended up using one of those cheap pumps that fits on the oil bottle, and a length of hose to fit up into the axle. This is with the car on stands under the axle.
Check a manual for the fill level. On my 7.5 axles, it is about 1 to 1 1/2 in below the bottom of the plug.
808Gt
115
Hawaii
Jan 15, 2006
  • Jan 15, 2006
kool thanks man......
so the friction modifier goes in after lets say 1 bottle lube oil.......
808Gt
115
Hawaii
Jan 15, 2006
  • Jan 15, 2006
also should i clean the axles then oilit up before installing them......?
88gt
794
Drillers cabin
Jan 15, 2006
  • Jan 15, 2006
I would clean them the best you can...button everthing up..the oil/modifier is the final step..
As far as when to add the friction modifier..put about 1/2 of the first bottle in, then the modifier, then top it off.
That's how i did it, worked for me..
808Gt
115
Hawaii
Jan 16, 2006
  • Jan 16, 2006
Kool thanks.......
old_blue
1,783
282
124
Jan 16, 2006
  • Jan 16, 2006
if you wait til last to put the modifier then obviously you run the risk of it topping out and then it just pouring out. +1 for adding one bottle of lube then the modifier, that is what I did when I did my gear swap.
808Gt
115
Hawaii
Jan 16, 2006
  • Jan 16, 2006
Cool.... thanks for your help.....
808Gt
115
Hawaii
Jan 17, 2006
  • Jan 17, 2006
Had a question about the MC.....
I got all the parts for the rear convrsion, going to stay drums for now...
But i will be buying sn95 front brakes and wanted to know if i can still use my stock MC for now till i get mor $$$
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
Drivetrain Installing new axels
  • cnorman31
  • Feb 1, 2025
Fox 5.0 Mustang Tech Feb 1, 2025
General karthief
