  • SN95 4.6L Mustang Tech
help on throttle body install
  • Thread starter Thread starter 03s281sc
  • Start date Start date May 22, 2005
03s281sc
245
maryland
May 22, 2005
  • May 22, 2005
im gonna install my throttle body today but, what wire do you use the voltmeter on to get it between .98 and 1. also how do u disconnect the plastic linkage attached to the throttle body, i think its for the crusie control
StangPro
441
Roseville, MI
May 22, 2005
  • May 22, 2005
The TPS voltage is rarely off, so I wouldn't even worry about it unless you notice low power at full throttle. It's more of an issue son the old 5.0's.
For the plastic bracket, it has a slot that you have to pull straight up away from the stud then pull off (for lack off better way of putting it).
There's some details here too:
http://www.stangpro.com/html/articles/tbinstall.htm
http://www.stangpro.com/html/articles/dragon.htm
twogts4us
4,188
12
79
Dunedin, FL
May 22, 2005
  • May 22, 2005
Agreed - I tuned mine by ear and tach. There isn't much adjustment to it anyway, and you can do it while the motor is running. Just put it about in the middle of the available adjustment and you'll likely be fine.
The cruise control pops straight out (either straight up or straight down, I can't recall right now - but don't force it - it'll pop pretty easily)
F
ForPointSex
395
Mercer, NJ
May 22, 2005
  • May 22, 2005
I used the bottom 2 wires to verify the correct votage.
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
