as stated, lift in istelf means nothing. You also need to factor in duration, LSA, and other variables. Plus with the 185 heads, you have 2.02 intake valves and need to measure PTV as you will most likely need to notch the pistons. FInaly, what rockers are you using- 1.6 or 1.7 as that changes lift.
