Help Picking out new cam....
  • Thread starter Thread starter youlost
  • Start date Start date Oct 23, 2006
1 of 2 Next Last
Y
youlost
  • Oct 23, 2006
I am currently in the process of rebuilding my shortblock. It will stay at the stock displacement and will have the stock TRW foreged pistons. My Edelbrock 6089 performer RPM heads will geta little porting/polishing and shaved 30 thousanths. Running 1.6 rockers and an E303 cam. Looking to get the most horsepower available by swapping the cam/springs using stock pistons. What have you guys found to be the best cam for a stock 302ci motor? Oh and I am running 24lb injectors/ 73maf / BBK SSI intake/ 70mm TB... Also, if you have dyno numbers to back it up that would be nice! Looking to get 320-350 at the wheels if possible...
Thanks in advance!
Brad
04sleeper
2,674
14
89
Dallas, TX
Oct 23, 2006
  • Oct 23, 2006
For the most power I would contact Ed Curtis @ FTI.
http://www.flowtechinduction.com/index.htm
Y
youlost
  • Oct 23, 2006
Yeah i heard them and Anderson Motorsports do a really good job on custom grinds, but I'm not looking to spend that much on this motor... really looking for a good off the shelf cam... thanks though!
04sleeper
2,674
14
89
Dallas, TX
Oct 23, 2006
  • Oct 23, 2006
OK. You asked for most power. For cheaper off the shelf maybe a TFS stage 1 or something similar. But remember you get what you pay for.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Oct 23, 2006
  • Oct 23, 2006
Being conservative on items like the cam will be the reason the engine fails to reach its max potential. I run an XE series cam and the return was excellent, but like a custom the price was substantial compared to Alphabet and TFS cams.
Y
youlost
  • Oct 23, 2006
How much did you pay for your cam?
Flavadave4
1,044
21
49
Utica, NY
Oct 23, 2006
  • Oct 23, 2006
I like my TFS1, but as mentiond before for max power a custom cam is the way to go, even one of the compcams i think would be better than what i have or any of the normal fms cams
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Oct 23, 2006
  • Oct 23, 2006
Comp cam was around the 300 mark.
D
Daggar
3,902
  • Oct 23, 2006
The cam is what pulls the entire combination together. Without the correctly matched cam, you can take 20 to 25% of all the money you've spent so far on parts and chuck it out the window. The days of sitting around the poker table and deciding what the best cam is, are gone. Consideration for your entire build needs to be taken into account in order to maximize power.
When you look at it like that... $300 is chump change.
BadAndy
766
Ohio
Oct 23, 2006
#10
  • Oct 23, 2006
  • #10
tfs stage-1 is your best off shelf cam, good price and performance, and driveability and idle quality 2nd choice would be custom
Y
youlost
#11
  • Oct 23, 2006
  • #11
Anyone ever heard of this company?? Cam Motion
http://www.cammotion.com/
they are local to me and they do custom grinds, one of my buddies had them grind on his e303 cam...
W
woodsy
Banned
Oct 17, 2006
35
#12
  • Oct 23, 2006
  • #12
ofcourse, good guys
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Oct 23, 2006
#13
  • Oct 23, 2006
  • #13
price wise maybe...BEST ots cam...I really have to disagree. My small valve eddy heads and unported typhoon were well complimented by my XE270 cam supporting numbers I would put up against any custom cam, low compression 302/306 in N/A form.
W
woodsy
Banned
Oct 17, 2006
35
#14
  • Oct 23, 2006
  • #14
best price maybe, best OTS, not even close, just a decent cheap grind
D
Daggar
3,902
#15
  • Oct 23, 2006
  • #15
I don't think that there is such a thing as "best off the shelf cam". That would be like telling a woman that the best purse on the planet is from Liz Claborne. Of course, her reply will be that the best purse is totally dependant upon what it is that this purse is supposed to along with.
The same is true with a cam. There is no one cam that is best for every combination. If you select an off the shelf cam then build around that cam then it's likely that they will be a good match. It is however, much easier and usually less expensive to build your combo then have the cam cut/selected to match that combination.
The point is that, shouting out name brands and model numbers for a bunch of cams is pointless without specific regard to the whole engine assembly.
04sleeper
2,674
14
89
Dallas, TX
Oct 23, 2006
#16
  • Oct 23, 2006
  • #16
They are another Excellent choice!
aleborjas
610
#17
  • Oct 24, 2006
  • #17
go comp cams XE266HR very good cam
EDC
342
63
58
In the new shop... 24/7
Oct 24, 2006
#18
  • Oct 24, 2006
  • #18
Thanks for the recommendation....
I believe he's already Emailed me but... just in case... The site has the info to contact me..
Ed
sn9550
1,184
Charles Town, WV
Oct 24, 2006
#19
  • Oct 24, 2006
  • #19
You could contact Jay Allen at www.camshaftinnovations.com. He can spec out a cam for your combo as well as EDC and some of the others. I'm happy with my CI cam.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Oct 25, 2006
#20
  • Oct 25, 2006
  • #20
give comp cams a call give lunati cams a call. talk to the tech guys give em a run down of your combo. they will steer you in the right direction.
1 of 2 Next Last
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
O
Computer swap
  • Oakman
  • Jun 22, 2024
  • The Welcome Wagon
The Welcome Wagon Jun 22, 2024
Oakman
O
Progress Thread Evolution of the 'Hudson Heap' plans (87 GT)
  • MadSquirrelTech
  • Jan 5, 2024
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 26, 2024
J
Need Help: 95 Mustang GT Engine Rebuild
  • jurban421
  • Jul 25, 2021
  • Other Auto Tech
2K
Other Auto Tech Jul 25, 2021
jurban421
J
A
Engine 1990 Fox wont rev over 3500 RPMS
  • alex.sweitzer
  • Oct 27, 2020
  • 2 3
15K
Fox 5.0 Mustang Tech Mar 21, 2021
alex.sweitzer
A
