Help Please... No Spark
Phatt_daddy
219
Hytop, AL
Ok so I finally got the engine buttoned back up with all connections and hoses in place. Btw I'm working on a 00 v6 auto. Made sure I have fuel pressure but I have no spark. I've tried 2 different coil packs. I don't have a volt meter to check but I have checked all grounds. Engine cane out of a 00 donor that was running before pulled but the car I'm working on has spent about 4 days out in the weather with no tarp covering the engine bay. Where should I start to hunt down my issue? The car turns over no problem.
Any help is greatly appreciated
Nate
Did you get it started? Do you still need help on this problem?
If not, it might help others if you updated the thread with what the resolution was.
If still a problem then maybe consider getting yourself a budget friendly Volt-Ohm meter (VOM). Why? Because the first round of questions that I would ask would involve voltage readings.
Reactions: imp
