  • 1994 - 1995 Specific Tech
Help!!......Please
  • Thread starter Thread starter 94import_slayer
  • Start date Start date Jan 23, 2007
9
94import_slayer
  • Jan 23, 2007
I finsihed my h/c/i swap and my car doesnt quite run right. There is no power under 1000 rpm and it barely stays running. Also I had to keep giving it gas for five minutes when I started it this mornin (under 30 degrees outside) to keep it alive. It does not have near the power it should have for the mods I put in, it feels weaker than stock if anything. The timing is set relatively low, havent had a chance to adjust it. The problem didnt seem to happen when I had my stock h-pipe on but I only drove it once before I put the o/r x-pipe on. I didnt hook up the tube that went into the cats on the h-pipe when i put my x-pipe on, I dont know if it throws off some sensor and puts too much fuel to the engine; which seems to be the problem because the fumes seemed very rich in fuel when it was warming up this mornin. Fuel system and MAF are stock if that helps any. Im open to suggestions, Thanks if you got any
F
fordtech28
312
Riverside Cali.
Jan 23, 2007
  • Jan 23, 2007
sounds like a vacuum leak to me re torque the intake bolts and you might need a tune our cars sometimes dont respond well to upgrades
95strokerPSU
986
Sacramento from Philly
Jan 23, 2007
  • Jan 23, 2007
I would first check the timing. Then I guess it would be a good a idea to check for a vac leak. Pull the vac line going to the brake booster and put a vac gauge on it. If the needle jumps all over the place then you've got a leak.
Depending on the cam you used, you probably just need a tune.
9
94import_slayer
  • Jan 23, 2007
I just remembered that i never plugged off the hole on my cai where a hose went to the valve cover. I'll plug that off and see if makes a difference.
9
94import_slayer
  • Jan 23, 2007
Didn't help. Plugged off the hole and went for a test drive. No power at all, back fired when I gave so much gas, and ran horrible trying to get above 1000 rpm in 1st. I might tinker with the timing when I get time.
divit250r
314
Columbia City, IN
Jan 23, 2007
  • Jan 23, 2007
Definitely check the timing and for any more leaks. I had a huge vac. leak on mine, where the egr tube wasn't seated correctly and broke the bottom ear on the elbow where the valve mounts. Lots of unmetered air made it sound like it had a huge cam and generally run like poop. Might recheck your firing order as well, since you had it all apart there may be a plug wire out of sequence. That's the easy stuff to start with at least. Good luck!
HISSIN50
34
129
Jan 23, 2007
  • Jan 23, 2007
I agree with getting a timing light on it.
Is it possible the dizzy was installed 180* out (we dont know how badly it runs exactly)?
Good luck.
9
94import_slayer
  • Jan 23, 2007
The timing was 180 out but I fixed it. The car will idle ok when its warm and sounds mean. It will also drive decent, except for the lack of power, once I get over 1000 rpm.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jan 23, 2007
  • Jan 23, 2007
The maf/ect/iat/02's are all stock and plugged in right? Timing at 10* before TDC? The spark plug wires are all in the correct order, right? (13726548, counter-clockwise on the distributor)
I would start yanking spark plug wires one by one (cylinder balance test) and see any cylinders do not affect idle when you yank them, or one will affect more/less than the others. After that, I would check the spark plug condition to check your a/f ratio.
Scott
9
94import_slayer
#10
  • Jan 25, 2007
  • #10
Got it fixed. It was timing. When i first got it done last week, I took it to my friends house who had a timing light and it read 10*. I bought a timing light and put chalk on the guage. It said 10* ATDC so I put it up to about 15* before TDC and the car rumbled like it should. I finally got a preview of the power, cant go all out cuase im still breakin in the new piston rings. Thanks for your help guys
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
