- Aug 30, 2005
- 347
- 0
- 17
Ok I think I've got the motor I want planned out for a coupe build. I'm open to any suggestions and if you have this setup be sure to let me know hp it put down. My goal is to get as close to 600rwhp as I can get. Will this setup even come close?
•Dart shp block
•Scat 331 stroker kit
•Afr 185 aluminum heads
•Custom grind cam
•Race ported upper and lower GT40 intake
•On3 turbo kit
•1.7 roller rockers
•75mm throttle body
•42lb injectors
•Dart shp block
•Custom grind cam
•On3 turbo kit
•1.7 roller rockers
•75mm throttle body
•42lb injectors
