help read asap.
  • Thread starter Thread starter mat82284
  • Start date Start date May 17, 2004
M
mat82284
889
  • May 17, 2004
ok i rechecked my supercharger and the guy didnt sell me a faulty unit. the shop took out bolts to the supercharger and it was comming apart i cant belive they did this. i fixed it it works fine now. the only problem im having is i have the timeing at 10 and when i rev the engine up it revs up slowly and my cars runs really slow also when i try to rev it past 4000 rpms it stops and backfires. what can cause this to happen???
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 17, 2004
  • May 17, 2004
turn the timing down to like 8 or maybe even 6 degrees. and gap your spark plugs at like 38 thousandths. you could be having boost problems also. get a boost gauge to check it out.
M
mat82284
889
  • May 17, 2004
when i turn the timeing up it revs quicker but when i turn it down it revs really slow what could cause this could it be the fmu??? the guy that installed it added a fuel line to my cobra intake manafold that lil thing that sticks out of it that sucks in air for the charcle container. could this be the problem?? could it not have enough fuel??
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 17, 2004
  • May 17, 2004
he put a fuel line there? if you can get pictures that would be nice...but i dont know why you would need a fuel line going to that.
M
mat82284
889
  • May 17, 2004
heres pics go here
http://mathew82284.home.comcast.net/1.htm
M
mat82284
889
  • May 18, 2004
anyone know im really need help. i connected that piece and tee it to the fuel regulator piece same thing. what can cause this if i turn the timeing up it runs good but when its down its terrible also when i hit 4500rpms my car stops running like it would if you rev to high
5ohjoe87
40
Pittsburgh,PA
May 18, 2004
  • May 18, 2004
The other line looks like a vacum line to the manifold that actuates the fmu under boost then the fmu at a certain psi closes the return fuel line to the tank raising fuel preasure and enrichining the mixture if the fmu is 10:1 that means the fmu for every psi of boost raise fuel preasure by 10 psi im preety sure that what it is. the setup is similar to mine .
M
mat82284
889
  • May 18, 2004
ok i understand how the fmu works but the problem im having is that my car revs slow and the timeing is at 10 and when i drive it drives slow when the timing was at 16 the car ran faster and reved better and when i hit 4500rpms no madder what timing it stops running like it hit the end of the rev limit but i know my car can run intill 6 1/2 ive done it before the supercharger went in. could this be not enough fuel or could it be something else??? could the fmu be broken??? what could cause this to happen and why the timeing goes up it runs better i was told never to run a supercharger above 10 timeing
86/92stang
159
Charlotte
May 18, 2004
  • May 18, 2004
what your plug gap at? may be blowing out spark not letting it rev higher. I wouldnt run above 10 degrees. I personally would also get rid of the fmu and get a chip and bigger injectors. Is there a dyno near you? At the very least id have air fuel checked and try to get it somewhat optimized. Also youre checking timing with the spout out correct?
86/92stang
159
Charlotte
May 18, 2004
#10
  • May 18, 2004
  • #10
Also i would take the hose off the throttle body and run a hose off the filler neck to fresh air after the maf but before the supercharger. The way it is now it can pressurize the crankcase which will cause issues including oil leaks. I would just cap the fitting on the throttle body.
M
mat82284
889
#11
  • May 18, 2004
  • #11
what do you mean by the throttle body gaping? do you mean spark plug gaping?
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 18, 2004
#12
  • May 18, 2004
  • #12
spark plug gapping....make sure your spark plug gaps are anywhere from 38 to 42 thousanths. thats what most people run with blowers
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
