  • SN95 4.6L Mustang Tech
Help! Speedo Problem
  • Thread starter Thread starter Kenney07
  • Start date Start date Apr 15, 2007
K
Kenney07
12
CT
Apr 15, 2007
  • Apr 15, 2007
Hi guys.. Im New to the board. I have a 98 GT B&M Short Throw, Flow Masters American Thunder Catback, BBK H Pipe, Cold Air intake, and a Diablo Predetor Tunner.
I Just recently rebuild the rear end and put pro 5.0's 3:90's in the rear end. Now my speedo is all screwed up and they dont make a speedo gear for the 3:90 . Any ideas on how i can my speedo accurate again?
Thanks
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Apr 15, 2007
  • Apr 15, 2007
First of all, you don't want to go with the speedo gear change. Using the non-stock one will cause it to disentergrate within months. Mine did. Can't your Predator tuner adjust this? Check the manual. If not, see my sig, get the SpeedCal and hook that up. I've had mine for years with no problems. Easy install.
K
Kenney07
12
CT
Apr 16, 2007
  • Apr 16, 2007
I thought the predetor could too but i guess the speedo only goes electronic with the computer at 99 and up. At least thats what the people at Diablo told me when i called them all ticked off.. So the speedo cal will make it 100 percent accuarate? I got a quote from a speedo shop for 250 to build a custom gear box. Which one would be the better choice?
RandyStinchcomb
1,159
Randallstown, Md
Apr 17, 2007
  • Apr 17, 2007
you can get it close to wthin 10 mph but its going to require a gear change on the output shaft of the trans, which meenS the trans ext housing has to come off and a 21 tooth oem gear on the end of the VSS
CobraRed_96_GT
1,421
UCSD/La Jolla
Apr 17, 2007
  • Apr 17, 2007
all you need is a speedcal, you don't need a new gear. Just program the unit for 3.90's
RandyStinchcomb
1,159
Randallstown, Md
Apr 17, 2007
  • Apr 17, 2007
well maybe he dosn't want to spend that kind of money when all you need is 2 gears for @$35.00
K
Kenney07
12
CT
Apr 17, 2007
  • Apr 17, 2007
Thanks for all the help guys.. Decided to go with the speedcal only because its supose to be more accurate and i dont need any speeding tickets and my millage on the odometer going up...
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
