Help. surging from 800-1200 rpm
sean4ky
While running at any speed from 800-1200 rpm the car surges or spudders. The rpm doesn't jump around at all. Also, this doesn't happen while in park or idling in drive while stopped. thanks for any input in advance.
1995 Mustang GT Vert
BBK aluminum pulley kit, k&n, 9mm plug wires, msd blaster, MAC longtubes, MAC O/R X-pipe, summit cat-back, MM full length subframe connectors, strut tower brace, slotted cross drilled rotors, 4:10 gears, Tuned by Paul's Automotive
Welcome!
Any codes?
Does this seem to be an issue with the engine management hiccuping, or with trans calibration shudder (it sounds like you have an AODE)?
Do you still have the EGR physically in the car? If not, was it's function turned off in the computer?
Tune up parts are relatively new? Take a good look at your plug wires - inspect each inch of each one. And/or look for a light show at night (misted water sometimes helps create said show).
Provide as much info as you can - little things the car does, etc, because there is a sink full of things that can cause issues like that.
Good luck.
