Well I disconnected the stock H-pipe and that didnt do it. Still wouldnt start. I dont know what to do now. When I had the engine on the stand, I had to swap timing covers for my 95. So I was directly at my timing chain. But for my 95 cover and waterpump to fit this engine, I had to remove some "bracket", that is sitting right under the bolt that is holding the cam in place/top timing chain bolt. For those of you who have a Chiltons manual, you can see this bracket at page 3-100 in the top picture(under the bolt and under the washer you can see the small bracket). Then I remembered wanting to align the timing chain properly with the timing marks so I just turned the engine over to see that the marks did matched. But I did this while the cam was still in place and the crank was still there so I dont think I screwed something there. Unless that small bracket had an important role. I was told not to worry about it from some knowledgeable guy that works @ my local SVT dealer. Us SN95 guys dont have it but the fox body guys have it on there.
What do do next ? Do I have an injector misfireing or blocked somehow ? Do I have fire on all plugs ? Is there a way to test an injector to see if the "plug" (2 male pins) is not burned or still electronicely ok ? How can I test the harness itself for every sparkplug connector ?
As you can see I'm in pretty bad shape and dont really know what to do. I really dont wanna do this but I think I'll have to open the whole front again to see if the timing chain isnt screwed up or something. Will install my 95 at the same time.
Thanks
