  • SN95 4.6L Mustang Tech
HELP....think I broke Trannie Linkage!!!
  • Thread starter Thread starter AirWolf87
  • Start date Start date Jun 27, 2004
AirWolf87
382
L I, NY
Jun 27, 2004
  • Jun 27, 2004
Well, it had to come sometime, i had my first problem . I drove to a friend's house and parked my car (all fine). As i was leaving i pulled out and stretched 1st gear a little bit and went to shift into second...and it grinded a little bit. Its done this before so i didnt pay attention. I understand that grinding 2nd gear is a common problem with these transmitions. well, i stopped at a STOP sign, put it in first, pulled away normaly, went to put it in second and the stick felt realy soft (like it wasnt connected to anything) and when i let the clutch out, it was still in 1st. I soon found out that it was stuck in first, i dont even have reverse. However, in first it drives fine.....so i dont think its the gear box...could it just be the linkage?
BTW...the first thing i thought was clutch, but the clutch acts normaly and grips and releases....i just cant get it out of 1st. The car is at the shop now...its sunday night so i wont actualy know anything until tomorrow morning. BTW, as long as my trannie is being worked on, has anyone fixed the second gear grind? is there a way to fix that or will i just have to live with it?
twogts4us
4,188
12
79
Dunedin, FL
Jun 27, 2004
  • Jun 27, 2004
Linkage? What kind of trannie is this? Sounds as if you bent a shift fork. Is that what you mean by 'linkage'? There isn't external linkage on your transmission like in the older transmissions.
AirWolf87
382
L I, NY
Jun 27, 2004
  • Jun 27, 2004
Thats the only thing i could think of...its a t45 trannie. personaly i dont have too much experience with it. The only time ive ever seen anything like what happenned on my car, it was a broken external linkage, but if you say it doesnt have one...then im stump ed
G
GinoGT
1,862
Jun 27, 2004
  • Jun 27, 2004
Most likely a broken shift fork.
AirWolf87
382
L I, NY
Jun 27, 2004
  • Jun 27, 2004
Is a fork a simple thing to fix? Its still under warrenty, but if i were to pay for it what would i be looking at?
G
GinoGT
1,862
Jun 27, 2004
  • Jun 27, 2004
I don't know about price, but you would need to tear into the transmission to fix it.
AirWolf87
382
L I, NY
Jun 27, 2004
  • Jun 27, 2004
lol cool....i dont realy care about price...warrenty...i think i might take advantage and drop in a clutch and flywheel
twogts4us
4,188
12
79
Dunedin, FL
Jun 28, 2004
  • Jun 28, 2004
Your 1996 is under warranty? Wow, that's cool!!! Let me know how it turns out - I'm interested to see what they say since you have a Tri-Ax.
stang9gt
1,247
State College, Pa
Jun 28, 2004
  • Jun 28, 2004
It is def a broken shift fork....Little 4$ part but lots of labor to take out trans etc....The dealership probably won't fix it cause those don't break without abuse....
AirWolf87
382
L I, NY
Jun 28, 2004
#10
  • Jun 28, 2004
  • #10
Well i bought the car 4 months ago (as you can see in the sig) from a used car dealer. I got an independent 3 year warrenty with it. The work is being done by a local transmition shop that i trust and have worked with before. Im sure he will overlook the triax. i havent heard from him today, hes getting back to me tomorrow morning. Im hopeing he can find a fatal "flaw" in the trannie and just get a new one.
BTW, i know the 1-2 grind is a very common thing on newer trannies, but mine had it too...you think that could have lead up to the problem?
G
GinoGT
1,862
Jun 28, 2004
#11
  • Jun 28, 2004
  • #11
Wait a second.....T45's don't have the cold 1-2 grind like the 3650's, do they?
Spreadman
two wheels
Houston, TX
Jun 28, 2004
#12
  • Jun 28, 2004
  • #12
I'm with him.
AirWolf87
382
L I, NY
Jun 29, 2004
#13
  • Jun 29, 2004
  • #13
i didnt think so...but i had it every once in a while on a cold engine usualy above 4000rpm....guess now i know why. That was it getting ready to let go. The funny thing is, i wasnt even pushing it, i shifted from 1st to 2nd at about 3500rpm....it was the most random thing
J
jbrown
393
Tallahassee, FL
Jun 29, 2004
#14
  • Jun 29, 2004
  • #14
my t45 never grinds from first to second, only time I have a problem is going into reverse but it isnt usually a grind. I have a triax too.
AirWolf87
382
L I, NY
Jun 29, 2004
#15
  • Jun 29, 2004
  • #15
yep you guys were right...i blew a shift fork. My mechanic is going to check over the whole tranny tomorrow and make sure it didnt take anything out with it and its should be back on the road by this weekend. As for the warrenty, its a coverred part, the exact words are "Transmition: All external and internal parts with the exp. of fluid, clutch disk and flywheel" but i know they will try to give me some on why they shouldnt pay for it...but they will, ill make them. lol
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
