Engine Help timing possibly
  • Thread starter Thread starter K1tha1
  • Start date Start date Apr 26, 2025
K1tha1
23
Somewhere thinking about Arizona
Apr 26, 2025
  • Apr 26, 2025
Good evening,
I hope all is well. I installed a new Edelbrock intake manifold I also changed out spark plugs, spark plug wires, distributor cap and rotor screw. My question is would a new aftermarket intake manifold effect my timing ?... Next I checked my distributor advance and I used my mityvac when I pump it holds nothing so I'm assuming it's bad... This is all because after I put the new intake manifold on when I let my clutch out and give gas it sounds like it's sorta missing and when going up any type of hill it wanna cut out and sound like a backfire.. any help ?
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,342
1,550
133
San Diego, CA
Apr 26, 2025
  • Apr 26, 2025
You have to remove the distributor when putting on the lower intake manifold, correct? Maybe you put it back in a tooth or so off? Did you make sure the lower was all torqued properly and sealed?
K1tha1
23
Apr 26, 2025
  • Apr 26, 2025
Surprisingly I did not have to remove it and everything is sealed no leaks
Admin Dude
Jan 4, 1985
43,560
21,727
234
Box behind Walmart
Apr 26, 2025
  • Apr 26, 2025
Duplicate thread
Fox Possible timing not sure
  • K1tha1
  • Apr 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2025
AeroCoupe
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
