  • 1994 - 1995 Specific Tech
Help! Transmission Woes
  • Thread starter Thread starter SeventyMach1
  • Start date Start date May 4, 2005
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
May 4, 2005
  • May 4, 2005
Well... I'll try my best to keep this short. Last week, my tranny was dumping fluid. As soon as I put more in, it came right back out. I inspected. It appeared to be coming from between the tailhousing and main case. On the lift, I found out otherwise. There was a hole on the upper side of the casting..... about the size of a penny. Well, I was going to pull it and have it aluminum welded, but the guy going to do it said he couldn't because it was into the casting crease. So I had a steel patch put on it with some kind of good sealant. That fixed it. For a few days. I knew there had to be something internal..... but it still shifted fine and made no noise. Until today.
Driving home today the most aweful "clunking" noise started. It won't take off in 1st without shaking you to death and making an extremely loud noise. the noise and vibration smooths out and get a little quieter as you progress through the gears. I dunno what's wrong with it. But I can't drive it. Bad.
So should I just get a new tranny? The casing is jacked up..... could I get core? And what should I go with? I want something good for @ least 350HP. I guess G-force isn't an option for me??? How hard are TKO swaps? Any write-ups on this? And where can I get the best deal on one?
Thanks.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 7, 2005
  • May 7, 2005
Anyone?
Trick95
2,298
Detroit, MI
May 8, 2005
  • May 8, 2005
Two questions....Did the patch you put on there fall into the trans? and Is the fluid level low now?
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 8, 2005
  • May 8, 2005
1. No
2. No
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 10, 2005
  • May 10, 2005
Okay.... I'm about to give up. This really sucks and I don't know what to do. I'm about to just go find a used T-5 at a junk yard. I definitely want something stronger.... but I need it A.S.A.P. I've done several searches.
Okay... a TKO 500. Is this a strong, smooth shifting tranny? What all will I need?
SilverFoxbody
149
  • May 10, 2005
How did that holw get there? You must have thrown your governors top and cracked the case. Drain it, pull the tailhousing (6bolts) and find out what is going on...
Q
qplk11
82
Maryland
May 15, 2005
  • May 15, 2005
I have no experience with TKO's but I heard they were a little notchy. If you are going to stay at 350-400 hp for a while, I would get a stock WC T-5 from ebay or something. I have a friend that had a T-5 rebuilt with the D&D 2.95 cluster and rebuild kit and he went 10.50's with nitrous every weekend for two years until the trans broke. I should add that he is a very good shifter and NEVER misses a gear but I think the same trans will last a while for you if you don't totally abuse it. Then when it needs a rebuild, go with a G-Force T-5. The only questions I have about the G-Force is if the case is as strong as the internals.
Q
qplk11
82
Maryland
May 15, 2005
  • May 15, 2005
Oh, and good luck! Hope this helps.
go-stang5.0
2,244
Glenview,Il
May 16, 2005
  • May 16, 2005
Actually the case is not as strong as the internals...It starts flexing to the point where things can pop out of place at about 600hp... but then again I am making somewhere between 300-400 hp so thats not a problem for me. Also, if does not add any weight to the car like just about any other tranny you get. Honestly, I dont know of anything lighter for our cars than a stock tranny. The only gripe is that its a bit whiny, but if you have an aftermarket exhaust it wont be a bother. If you get any of the tremecs, expect to gain about 50 lbs.
go-stang5.0
2,244
Glenview,Il
May 16, 2005
#10
  • May 16, 2005
  • #10
Sorry I forgot to mention, I was talking about g-force's gearset.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Y
2004 Mustang GT AUTO (4R70W) Grinding noise when going in R or Drive does it as I put it into park too
  • yellowandblack
  • Dec 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 21, 2024
89ripper
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
