I need some ideas from smart mustang guys...
This morning I tried to start up the stang, the car seemed to start to crank for about a split second, then white acrid smoke started billowing from underneath the hood, more from under the drivers side near the windshield. I cut everything off, grabbed the fire extinguisher, opened the hood, but... no fire. So this evening I did a visual inspection, no burnt wires I can see. I then put the key to the on position. I mounted my crane ignition box near where the smoke was coming from, but the ignition box self test was coming up fine. Then I did an EEC-IV key on engine off self test... no stored codes, and the self test went fine, so I cranked the car and it started fine with no smoke.
So I'm glad it's starting, but I'm just afraid my car is going to burn to the ground in the near future. What should I look for? A loose ground? Any other ideas??? Thanks, guys
