  • SN95 4.6L Mustang Tech
Help!!! Window won't come down anymore!!
  • Thread starter Thread starter Wikkdgt
  • Start date Start date Mar 22, 2004
Wikkdgt
445
Cincinnati, OH
Mar 22, 2004
  • Mar 22, 2004
Today when I left work, I went to put my passenger side window down and it would not go or even make a noise like it was trying to. I went to Ford and asked if it could be a fuse and he said no because the Driver side still works. I guess both windows run off of the same fuse?? Anyways they said it might be the switch, but neither one works and what are the chances that both would go bad at the same time. So I am thinking it is the motor. A friend of mine can get me one for 50.00. I am just wondering how hard is it to get the door panel off and replace it. Ford want like 300.00.
R
Ryno
49
New Orleans
Mar 22, 2004
  • Mar 22, 2004
It is not that hard. The door panel comes off easy and you have to take the speaker out. Three bolts hold the motor in place. It took me a little less than two hours to change one and it was my first time ever doing it.
sjrtx
151
Houston-NW side
Mar 23, 2004
  • Mar 23, 2004
if its a regulator-its a bitch to do, and expensive. look into the 300 dollar range. rivets have to be drilled out, and rebolted.
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
Paint and Body Window bushing
  • JD1964
  • Aug 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 19, 2025
General karthief
89 power window issue
  • Creomod
  • Sep 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
J
Car won’t start
  • JLB
  • Nov 15, 2025
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
