Help with 04 v6
Can anyone please tell me why my mustang runs out of gas and pops when I turn sharp? Pump works but it's getting worse. Getting a code that reads random misfires and you can tell that the fuel is just not getting to the motor.
Check you fuel filter may be clogged, check your gas may have water in it. Draw gas into a glass jar, let it sit for a long time maybe overnight gas floats on water it will be clear at the bottom if water is present. Check plug wires pull a night test. Pops when you turn, posable ball joint? Try these basic's.
Regards ;)
